Key bites, would not turn to start
The key goes in but would not turn to start the engine. Is it the locking mechanism? Can it be fixed or I need a new one with a key?
1984 944 N/A Passadena Gold, No Sunroof 1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black 1971 Cuda 340, A/T, Rallye Red 1970 Cuda Ragtop, 383, 4 Speed, Triple Black |
Have 944, will restore
Sometimes I have similar issues with my car as the key is worn. Just playing with it seems to do the trick. Does your key work fine in the door, hatch, and glovebox?
Also ensure that you're steering wheel is not locked. A you know, a locked steering wheel will prevent the ignition lock cylinder from turning.
85.2 944 Guards Red M456 5spd 85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd 84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary 04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd 84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE |
Your ignition lock is worn out. If the key work in the door and hatch, the key is good.
The lock needs to be replaced.
Good luck, George Beuselinck |
A locksmith might be able to replace the worn tumblers, if that is the problem.
Early '85 |
I sprayed white lithium grease on the key and it works great, at least for now.
