Hamad89's Avatar
83 944 squats upon acceleration / hesitant acceleration
Hello guys
I drove my 83 last night and noticed it titls backwards when accelerating like a drag race launch ,
i recently added Koni sport shock inserts in the front as the originals were very bad and coil spring are blue coded originals , the rear are factory Koni sport shocks (externally adjustable) , maybe its due to the rear shocks being set to soft or maybe leaking gas?
also accelerating and throttle response feels delayed with slight bucking ( throttle cable? ) , eventually when i hit a ramp at low rpm , the engine stalls and dies. my mechanic also said its a lose wiring harness to the dme
my car has a new fuel pump , fuel filter , air filter , new distributer cap and rotor , new spark plugs , new original engine mounts , the injectors look rusty on the outside and my tires are very old,
appreciate your kind input
Best regards,
Hamad
Old 05-06-2022, 01:08 AM
Your rear shocks need to be adjusted so that they resist the squatting.
I agree that intermittent loss of power can be due to bad wiring.
Good luck.
Good luck, George Beuselinck
Old 05-06-2022, 04:05 AM
Hamad89's Avatar
Good luck.
Thanks a lot George for the input!
Regards,
Hamad
Old 05-06-2022, 01:17 PM
You could try tightening the setting on the fronts too since that would result in less front end extension.
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 05-06-2022, 04:09 PM
Hamad89's Avatar
Thanks , will have it setup as well.
Old 05-10-2022, 03:55 AM
Tags
944 1983
