Smile's Avatar
Cool Need a fast answer, Turbo gauge, where to connect???
Hi, need a fast answer.
I'm just about to go and get my turbo gauge and I'm unsure where to connect it to. It has an "vacum" scale also, so I would like to install it AFTER the throttle. Before the throttle I know where to install it, but after, I'm unsure. Have any of you any ideas, which hose I could "jump"!
Its a 924 Turbo, -79.
Thanx
/Smile
/ Porsche 924 Turbo -1979.
Two coloured (original).
http://www.geocities.com/Pipeline/Valley/3424/porsche
Old 05-28-2003, 04:30 AM
AFJuvat's Avatar
Sorry, no idea.
Does the gause come with any documentation?
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-28-2003, 07:26 AM
I have one in the shop, I'll take a look this afternoon for you. Basically it has to be from a port on the intake manifold behind the throttle body so it will get the vacuum and boost. I don't recall any ports though, which is probably your problem. There is a temp sensor but you really shouldn't move it. Hmmm, again, I'll take a look.
Old 05-28-2003, 08:03 AM
there is a nipple coming off behind the throttle body or on the throttle body but its after the butterfly so it will read manifold vacuum and pressure, thats where i hooked up mine, good luck
John
Old 05-28-2003, 01:19 PM
Smile's Avatar
The instruction for the gauge is to either drill a hole in the intake manifold or to use a vacum line.
Drilling a hole, I 'll not do that :-)
I first tried to use the vacum line from tthe intake which goes to the distributor, but the conection/hole from the manifold is so tiny, so the gauge didnt read and pressure. Only vacum.
So I tried another hosewhich also is connected to the brake...... Now I get a reading, but only top. 0.5bar. It should be 0.7-0.8.
The question now is, am I to far from the intake to get the correct reading or is the turbo/wastegate "bad"?
Any ideas?
Old 06-01-2003, 11:12 PM
Smile's Avatar
How about to put a T coupling between the intake and the wastegate!?
I wont get any vacum reading, but the pressure reading should be very accurate. I think this is how its suppose to be done, or?
I just a little bit affraide, if the T coupling break, I will have a turbo running to heaven.
What do you say, should I go for the wastegate hose?
Old 06-05-2003, 03:23 AM
