968 Airbag bypass connector - where does it go ?
Hi,
I have inherited one of these airbag bridge connectors that stops the airbag light coming on. It basically just jumps two pins on the connector. Crazy price from Porsche but a friend found one in a box of old bits.
Before I go poking around, where does this plug in - under the dash somewhere ?
Old 06-25-2023, 06:04 AM
I think the connector is the same one used for the warning light reset:
Under the dash on the passenger's side of the vehicle (LHD cars), you'll find a white Molex connector with three female pins (diagram below). The center pin (Pin #2) is used to apply a ground to the connector in a series of specific timed steps to reset the air bag warning light. You can use a wire with a pin connector to make the ground connection or the bare end off a wire that has been tinned with solder. In either case, make sure you have a good connection in the pin (i.e. if using the bare end of a wire make sure the fit is snug enough that the wire will not fall out).
Air Bag System Testing
Air Bag Warning Light Reset
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP
Old 06-26-2023, 11:19 AM
In the Fires of Hell.....
kdjones2000's Avatar
That connector is for '88 and earlier models of 944's.
The 968 should have a round connector for that. I am thinking that the bridge connector you are referring to is a resistor that fakes the system out to think that an airbag is installed.
If that is the case, then it would replace the actual airbag at that connector.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-26-2023, 07:09 PM
