Question Problem with Pop-up Headlights
My pop-up headlights don't come up when I want them to. At night, when I turn on the engine, and twist the headlight knob all the way to the right, I can see the lights come on, but they don't pop-up. When I drive for about 2 minutes with the knob in that position, the lights usually pop-up. In addition, when I try to turn them off, the lights turn off, but they don't go down. The complicated part is that it is completely random. Some days I'll be able to turn the knob, and they work as intended, the lights come on and they pop up at the same time. Other times, I have the problem of the lights not popping up. Has anyone else had this problem or know what might be wrong?
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 06-29-2003, 11:38 AM
Try cleaning or replacing the relay on the motor. First guess is dirty contacts.
Bob S. former owner of a 1984 silver 944
Old 06-29-2003, 11:57 AM
Send a message via AIM to XJOSHX Send a message via Yahoo to XJOSHX
Mine did that and it was the switch. If I would push the switch towards the dash once they are on they would come up. try that and see what happens.
1983 944 - Project Time!
1986 944T (Stolen)
1987 944 N/A (Sold)
1984 944 N/A (Sold)
1986 944 N/A (Sold)
Old 06-29-2003, 01:18 PM
Eleg's Avatar
Been there! I noticed that if I pushed on the little silver box (relay) next to the motor, up they came! Watch the hands! I just cleaned the relay/plug and they have been working flawlessly ever since.
Old 06-29-2003, 03:00 PM
Thanks guys, especially Eleg. I just left my lights up last night because I couldn't get them down after turning them on and off a couple of times. I just tried pushing on the "little silver box" and the lights went down! I guess I need to go clean that area off and see if that solves the problem for good. Thanks!
'86 951 blk/blk
Old 06-29-2003, 03:32 PM
SoCal Driver's Avatar
Also replace the rubber boot if yours is torn or cracked. You will need a special metric tool to push the pins out of harness connector.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-29-2003, 09:15 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
Where can you get those rubber boots from? I need one too but haven't found anyone that carries them.
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 06-29-2003, 09:20 PM
Try the dealer.
The pin removal tool is a common item at well stocked autopart stores.
Search here for a thread on replacing the 944 mirrors with ones off of a 968. Think there is a manufacturer and part number.
Old 06-29-2003, 09:30 PM
vott does ziss do?
ronin's Avatar
I've had similar problems. Quite often laately when I turn off the headlights, they will go down but come right back up again and repeat this ludicrous maneuver ten or twenty times before it stops. I'll check the relay now that I know where to look but if someone else has had this problem and had to solve it in a different way, let me know.
Old 06-29-2003, 09:40 PM
