Yan Yan is offline
(Urgent) Speed/reference sensors
Hi!
I think that I finally found the no-spark problem source on my 951. I checked the resistance of my speed/reference sensors: my speed sensor indicates ~900 ohms while my reference sensor doesn't indicate anything at all, the circuit is opened!
If it is opened, I guess it's a broken internal wire or connection? Is there a way I can repair it myself? If so, where would it go bad first to result in the opened circuit problem?
Thanks alot, I really miss the boost of the 951!
Old 07-13-2003, 02:22 AM
Yan Yan is offline
Bump...
Old 07-13-2003, 06:57 AM
SoCal Driver's Avatar
Not repairable. Has to be replaced. Check Pelican for a price.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 07-13-2003, 09:29 AM
I see them on eBay often for $20 - $30...new they're about $120
seems to be a common 'no spark' fix lately...here's more info:
http://www.clarks-garage.com/shop-manual/ign-02.htm
PITA to remove...lots of WD40 yadda..yadda
often the bracket breaks when you try to get it out..then you have to do the .8mm washer trick etc
good luck
Tom
Early '85 944
Old 07-13-2003, 01:14 PM
