(Urgent) Speed/reference sensors
Hi!
I think that I finally found the no-spark problem source on my 951. I checked the resistance of my speed/reference sensors: my speed sensor indicates ~900 ohms while my reference sensor doesn't indicate anything at all, the circuit is opened! If it is opened, I guess it's a broken internal wire or connection? Is there a way I can repair it myself? If so, where would it go bad first to result in the opened circuit problem? Thanks alot, I really miss the boost of the 951! |
Bump...
Not repairable. Has to be replaced. Check Pelican for a price.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
I see them on eBay often for $20 - $30...new they're about $120
seems to be a common 'no spark' fix lately...here's more info: http://www.clarks-garage.com/shop-manual/ign-02.htm PITA to remove...lots of WD40 yadda..yadda often the bracket breaks when you try to get it out..then you have to do the .8mm washer trick etc good luck
Tom Early '85 944 |
