scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
Question yes yes another annoying question from the new guy
ok another question, seems i do this a lot... i should know everyhting by now.
anyways, i have an oil leak from the front of my engine, i have talked to the mechanic who used to work on my car and asked him if he knew where it was coming from. he said that the guy who owned it before me and one of his friends did the water pump and timing belt together... oddly enough i have a reciept for it though, but he said the didnt change some seals, dont remember which ones and thats where he thought he remembered the leak coming from. today i got under the car and looked for myself. and the oild leak is coming from the lowest pully on the front of the engine, i think thats the water pump and something else that the timing belt is connected to. when i started the car and looked at the timing belt from under the car it vibrated a little every few seconds. the timing belt is in very good condition. i was wondering if i should have this all redone or just have the belt retensioned and just put oil in it whenever it is needed and wait till i need a new timing belt. when i was under the hood i also saw this aluminum looking bar that goes above the radiator that i dont know what it does, its vibrating a little and makking a the things that hold it are making a rattleing noise that i can only hear when i have the hood open, should i worry about it and what is it?
that u again!
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 07-23-2003, 06:02 PM
Your description is a little "fuzzy." It is difficult to determine exactly what you are describing because unless you remove the covers you cannot see the timing or balance shaft belts. This leads me to believe you are actually describing either the power steering or the Alternator/A.C. Compressor drive belts.
How about posting a picture or two?
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 07-24-2003, 06:04 AM
TCMdocs944's Avatar
If you don't have a digital cam do a search for pics and just repost them.
(I do think, however, that a cam should be in everyones tool chest)
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 07-24-2003, 06:17 AM
seaboltman's Avatar
i *think* what hes saying is that the water pump belt is vibrating. If you havent, Now is a GREAT time to check fluid levels. maybe even change the oil.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 07-24-2003, 08:44 AM
That still doesn't work for me. The only belts you can see with the covers on are the power steering (small 'V' belt) and the Alternator/A.C Compressor (Wide "Poly-ribbed" ) belts.
The 'aluminum bar' above the radiator sounds like the linkage for the headlights.
Pictures will clear up the confusion.
Cliff Hipsher
'87 944 India Red
Old 07-24-2003, 01:20 PM
Hm, while we're on this topic, anyone know what size the power steering pump belt is? I'm too lazy to jack up the car, pull off the belly of the car to get the size of the belt.
'86 951 blk/blk
-968 M030 Sway Bars with delrin bushings
-IceShark headlight kit
-Koni Yellow Sport Adjustable struts and shocks
-225 lb springs up front
Cleaned grounds = happy 944
WTB: 951 black passenger door/fender
Old 07-24-2003, 02:06 PM
well i did take pictures, but the cable for my camera is missing in action :-( and i know what, i think that porsche944 is right, i just looked under the hood, the aluminum bar is the linkage for the headlights. and i never noticed that there were covers on there before... oops. well the oil is coming from lower most wheel that the wide belt goes around and the lowest wheel that the thin belt goes around. and its the wide one that is shaking.
Old 07-24-2003, 02:12 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Is the oil coming from the center lower pulley and is an inch or so wide? I suspect the front crank seal and if thats is the case, yes re do the entire job. This is why when it is said to replace everything to do just that! Doing the belts and pump and not the seals is grounds for another round of timing belt work. But it sounds more like a crank or balance shaft seal is gone!
The aluminum bar is most likely a power steering tube running from the rack to the pump. The return and cooler line run under the xmember, around the radiator and in front right corner of the fender by the ps fluid tank. Look at the lines and see if that is the same one you see. Take a cable wrap and secure it. But it is not a major concern. Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 07-24-2003, 02:25 PM
