noise
I realize the difficulty descibing noises on the board, but can anyone tell me the difference between wheel bearing noise and worn torque tube bearings? Or a test to determine either, many thanks for your thoughts
944s2
Old 07-30-2003, 02:20 PM
AFJuvat's Avatar
Jack the car up and spin the wheel (obviously, car will be in neutral)
Worn bearings make a vague grinding type of noise
torque tube makes the car sound like an airplane motor when worn.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 07-30-2003, 02:34 PM
Is that a sort of throbbing sound? Thanks for the lightening reply!
944s2
Old 07-30-2003, 02:37 PM
If the car is in the air and the in neutral, spinning the wheels will not spin the torque tube. At best you'll spin the idlers in the diff.
To spin the torque tube you need the tranny in gear and the clutch down and you need to spin both wheels at the same time and in the same direction.
'87 924S 5sp
Slowly recovering from a warped head
Old 07-30-2003, 06:06 PM
Well thanks for the input, I'm now sort of sure it's the tube, what sort of time am I looking at to remove, ball park figure?
944s2
Old 07-31-2003, 02:02 PM
there are a couple of write-ups on this...here is one...(go to the bottom):
http://www.924.org/techsection/7transaxle.htm#3%20-%20torque%20tube%20rebuild
and another:
http://www.tech-session.com/kb/index.php?page=index_v2&id=56&c=4
(ahhh...Martin of course)
Tom
Early '85 944
Old 07-31-2003, 05:55 PM
Cheers Tom.
944s2
Old 08-01-2003, 01:16 PM
