Interference engine
My 93 944 has stripped the teeth off the timing belt at the crankshaft pulley. Did i just bend some valves or is this even an issue? Hoping for the best.
You have a 93 944!?! Damn! I want it...I will buy it off you for 30 kilobucks! And all this time I thought they stopped production...what size motor does it have? Ok..sorry for being mean..I had to do that...Assuming you mean 83? Does the car run? I would definately be scared if i were you...You could have 8 nice paperweights.
If you don't live life on the edge, you take up too much space. |
Sorry 83, no it does not run, It turns over very nicely but the camshaft does not move. I had a turbo daytona years ago and you could break timing belts all day long without a valve problem. I was praying that the porsche might be the same
the 944 is an interference engine...the daytona is not. Yes, i'm sure you have damaged something. If you need a head I have one...gearhead290@hotmail.com if interested
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
No NO...your screwed...I am very sorry to be so blunt...but if your crank is spinning and your cam is not...you've got a nice juice squeaser...but thats about it. Those valves are 'bout as straight as Richard Simmons.
OK any one know of a good manual for these cars?
Steve MA 83 944 red tan int |
Since the car only has 50K on it i guess it is off with it's head, ha ha ha I crack my self up!!!! Thanks for the help
More likely 150,000 if not 250,000 as the odometer has 5 digits and not six.
And yes you have bent most if not all the valves. What were you told about the timing belts on the 944? The Haynes 944 manual will be a good start. See them all the time on eBay for $14. If you are serious about keeping the car then the factory workshop manuals are worth getting. About $300 a set in paper or from free to $20 as PDF's on CDR.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
vott does ziss do?
for those that still don't know what an interference motor is. let me just put it this way. iffn ya dont keep after dem belts, sooner or later its really gonna interfere with yer cash flow
![]() as mfp is about to find out
Thanks for the replies. Socal driver it is actually 50k. I have all the documentation on the car. Including the owner history and the milage each owner claimed when registering the car.
WOW!
What luck. Well maybe not as lucky as it would seem. The timing and ballance shaft belts should have been replace at 30,000 miles or about four years as they deteriorate to where they loose teeth. So what were you told about the timing belt when you bought the car? P.S. With such low milage you can get away with just replacing the bent valves and lappin in the new ones as long as there is no significant damage to the valve guides. P.P.S. Add your location and the year/model of you car to your info. Use the signiture line for the year and model.
Ok I have a manual and I read about dealers doing the cam belt tension. Any other way to do this? Tool available?
Parrothead member
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
