Scott R's Avatar
I may have solved my 2 year long suspension problem (pic attached)
In my never ending quest to discover why I have a popping thunking noise when I stop hard or roll backwards down a hill and stop, I decided to seperate the tie rod ends tonight.
I have replaced the entire suspension with the exception of these little guys, and what did I find? The tie rod end is jammed to on side! I have to use a hammer to move it, check this picture out:
Even if this is not the problem, it sure does answer a few driveability issues that I have.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-26-2003, 05:36 PM
Roger Hall's Avatar
Congrats feels good to idenify and repair a problem. Good job.
I have a similar isue with the Intrepid when in reverse there is a noticable wobble from the right front. I am not looking forward to tearing into this job.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 08-26-2003, 05:46 PM
Scott R's Avatar
Thanks, and what's even more interesting is that I discovered that I have an LSD transmission from a 92' in it. I was testing the CV's in gear for the first time ever and noticed that as I rotated the left wheel forward the right wheel turned in reverse. I then pulled the numbers off the side of the transaxel, and sure enough someone dropped in an LSD tranny in some point. According to the option code sticker it did not come with this option.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-26-2003, 08:10 PM
Roger Hall's Avatar
YeeeHaw!!!!!!!!
Roger Hall
81 924 N/A
Old 08-26-2003, 08:16 PM
I you had a limited slip diff then it seems both rear wheels would turn the same dirrection when you move one. If it isnt limited slip the spyder gears would cause one wheel to turn backward if you turn the other wheel forward. I know that is the way other cars work I would think Porsche would work the same way.
1987 944s 86k never too old to enjoy the performance of a fine auto
Old 08-26-2003, 09:14 PM
Oh yeah, congrats on finding your suspension problem.
Old 08-26-2003, 09:15 PM
Scott R's Avatar
If they turned the same direction that would be a "posi" type setup, both wheels turning forward when pressure is applied, correct? I can let the clutch out in 1st, hold a tire and the other still spins.
Anyway my last DE instructor was convinced it was LSD even though I told him the option tag stated otherwise.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-26-2003, 09:34 PM
If you have a LSD, both wheels rotate the same direction is you spin one of them. If you let the clutch out, then both wheels should spin at the same speed.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-27-2003, 12:49 AM
Wolf1's Avatar
Just curious, does the Porsche LSD use friction clutches like most posi units or is it a "ratchet" style similar to a Detroit Locker?
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 08-27-2003, 06:35 AM
BlueQuestTSi's Avatar
"Posi" is an LSD, it's just a name brand thing "Positrac". Both wheels would spin in the same direction if the back end of the car is jacked up and one wheel is spun. With my LSD on the Conquest, I can actually jack up one side of the car and break the lugnuts loose on a back wheel, even with the car out of gear.
Tires that spin in opposite directions is just a side effect of a standard differential.
Jack
86 Red 951 - Turbo Twists, otherwise stock for now
83 Black 944 w/86 951 front end - still down and out, but coming back slowly.
02 Altima SE 3.5 - grocery go-getter
00 Yellow Ducati Monster 900i.e. 88 Chrysler Conquest TSi
Old 08-27-2003, 08:38 AM
