Honey Badger
theFONZ's Avatar
idle problem
After a little off couse excursion at the Bogus Basin Hillclimb, I have a weird idle. It idles at 2300 unless I pull the gas pedal back then it idles normal. if I rev it up it stays at 2300 again.
Is there some type of idle valve I should check.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 09-01-2003, 08:32 PM
Check the throttle cable and the throttle return springs.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 09-02-2003, 06:26 AM
SoCal Driver's Avatar
Clean all the dirt out from around and under the gas pedel.
Also the lever arm that comes down and the guide on the back of the pedel has a tendency to develope flat spots.
Pull back the rubber weather boot on the throttle cable in the engine compartment and spray a teflon based lube down it. Use shop air to help it along.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-02-2003, 07:33 AM
