Honey Badger
idle problem
After a little off couse excursion at the Bogus Basin Hillclimb, I have a weird idle. It idles at 2300 unless I pull the gas pedal back then it idles normal. if I rev it up it stays at 2300 again.
Is there some type of idle valve I should check.
1978 911SC 1953 Piper PA-18A USAF EOmfD |
Check the throttle cable and the throttle return springs.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
Clean all the dirt out from around and under the gas pedel.
Also the lever arm that comes down and the guide on the back of the pedel has a tendency to develope flat spots. Pull back the rubber weather boot on the throttle cable in the engine compartment and spray a teflon based lube down it. Use shop air to help it along.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
