any tricks for removing old stone guards?
I want to peel off my old stone guards but they are tearing off a millimeter at a time. I tried heat from a blow dryer and alcohol but nothing seems to work. What's the secret?
'90 S2 Cabriolet
Old 09-08-2003, 08:21 PM
Send a message via ICQ to interglossa
Yeah a hair dryer or direct heat source, a plastic scraper and patience (sp?)
My '83 Sets me free!
Old 09-08-2003, 11:06 PM
SoCal Driver's Avatar
Might have to get a hot air gun like is used for shrinking pallets.
A plastic windshield scraper works.
Also use denatured alcohol.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-08-2003, 11:10 PM
paulc's Avatar
do a forum search..........been there, done that
87na guards red(mine)
98 suburban(mine)
04 4Runner(wife's)
Old 09-09-2003, 05:19 AM
I used bug and tar remover, if you can find it in the can, not the spray. Plus, a hard plastic cake spatula to scrape. First I soaked the guards with the tar remover, then started scraping. It takes HOURS.
Richard
_______________
'00 Mazda 626 ES (this car rocks)
Schwinn Apple Krate
College days...'69 Hurst/Olds and '71 Roadrunner
Old 09-09-2003, 10:45 AM
ok, thanks guys. I checked the search forum and there is no quick and easy method. between heat, adhesive removal substances and a scraper, it looks like a couple of evenings of patient labor is unavoidable. luckily I feel my 944 is worth it.
'90 S2 Cabriolet
Old 09-09-2003, 09:47 PM
vott does ziss do?
ronin's Avatar
like Hugh said, a hair dryer won't cut it (no pun intended) as a heat source. you'll need a hot air gun. just be careful with the paint.
Old 09-09-2003, 10:24 PM
bearone2's Avatar
Jet/diesel fuel works well as a tar remover. I used it for years without any paint damage.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 09-09-2003, 11:20 PM
vott does ziss do?
ronin's Avatar
ahh, the many uses of good ole JP4
Old 09-10-2003, 11:20 AM
bearone2's Avatar
You know if they could come up with a perfume that smells like tires, gas, new leather, MEK, grease, with a hint of, Corona, I'd be in heaven.
Old 09-10-2003, 08:39 PM
