Crippler's Avatar
Relay problem
Okay I have had some trouble with my cooling fans working. Now the relay in slot 1 is burnt up so I know that has to be replaced and I was looking at the cooling fan relay in slot 3. I think the wrong relay may have been installed, does anyone know the correct part numbers?
Here is what I have now:
Slot one 944 615 113 00
Slot three 171 937 503
1984 - Porsche 944
1994 Grand Cherokee
6inch Lift, 33" TSL'S
Old 09-26-2003, 10:47 AM
Crippler's Avatar
From what I can gather part 944 615 113 00 has been updated to 944 615 113 01. Is this right?
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2003, 11:12 AM
Crippler's Avatar
bump
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2003, 12:08 PM
These sites might help...
http://www.geocities.com/MotorCity/1760/earlyfusepanel.html
This one has a photo, and layout of the fuse and relay blocks.
http://www.clarks-garage.com/
Clarks garage has a pretty good page about the DME relay, which is in between the two you are having a problem with...just in case.
Not sure on the Part#, but the updated one looks reasonable.
Good Luck
Old 09-26-2003, 12:25 PM
Crippler's Avatar
So no one can verify the part numbers for me?
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2003, 08:50 PM
ae1969's Avatar
Send a message via ICQ to ae1969
944 615 113 01 being the A/C relay ....
Cooling Fan relay being 141 951 253 B.... for the early 944
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-26-2003, 09:14 PM
Crippler's Avatar
yeah, I just found another site suggesting that 944 615 113 01 be the updated one. Also I have 171 937 503 as the fan realy now, but I am going to change it to the 141 951 253B that I guess it's supposed to be. I am also going to go a head and replace the thermo switch. That should take care of everything
1984 - Porsche 944
1994 Grand Cherokee
Old 09-26-2003, 09:17 PM
For some reason I had a couple of the a/c fan relays go bad. I wired both fans together from the thermo switch so that they both come on at the same time. Anyone know of a downside to doing this?
Old 09-27-2003, 03:11 PM
