Ok I just replaced the inner and outer bearing today and noticec my rotors were WAY under spec. Anyway, for the past 3 weeks I have herd a muffled "clunk/slow pop" sound when the front right tire went over a bump or when I made a hard right or left turn. I was praying it was the bearings but alas It did the same thing when I pulled out of the shop today. Is something loose? or what would be some tings to look for?
On a lesser note. Where is the GD diagnostic port on a 85 1/2 944? I was going to adjust the idle but I could never find the thing. Many thanks, Ven |
Jack it up again, and see if you can wiggle the wheel on the lower ball joint axis. Sounds like minor ball joint seperation. Possibly lower control arm bushings. Other thing it could be is a loose sway bar or a broken sway bar bushing. Check it all.
------------------ PORSCHE There is no Substitute! [This message has been edited by 88_944 (edited 06-09-2001).] |
I looked for the bushing there seem to be 3 different sizez? 20mm dia thru 23mm dia. Ok, I am lost. help
You will need to get a caliper and measure the diameter of the sway bar to get the correct size.
Well will it be safe to drive for another week or so? I plan on ordering the rotors and bushing in the morning probally will be next Saturday before I get to work on it.
So has anyone found that diagnostic port yet? ![]() Hey! thanks everyone for all the help!! |
Ven, I had the exact same problem. I checked all the sway bar bushings and even entirely removed the sway bar, but still clunked. I ended up getting a used control arm off Ebay that had the rear caster block on it and changed it as a whole unit. The clunk dissapeared. I check the old block and the rubber was breaking off.
I knew that it couldn't be the ball joint as it was very tight. [This message has been edited by marksportcts (edited 06-10-2001).] |
