lousailor's Avatar
Send a message via AIM to lousailor Send a message via Yahoo to lousailor
Unhappy Need some Help
Hopefully this is simple. I'm replacing the front bearings. The Haynes says after you pull the hub off, remove the inside grease seal by 'carefully' prying it off with a screwdriver. I can't get the thing to budge! What's the best way to pull these things out? Thanks
Louie
'85 (Early) 944 - Beater
'87 924S - Crunch/Rebuild
'76 924 - Long Gone
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
Old 10-04-2003, 02:36 PM
The front seal is only pressed in and shouldn't take much effort. Use a flat bladed screwdriver (the blade fit on the inner part of the seal, so the screwdriver will be across the hub bearing) and and carefully lever the seal out. Use a piece of wood to avoid damaging the hub. Before trying to hammer out the bearing races, heat up the hub. Put the new races in the freezer.
If you hammer the bearing races out with heat you can damage the hub and the new bearing race will be loose.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-04-2003, 02:52 PM
AFJuvat's Avatar
yep, exactly what Britwrench said...
use a small piece of wood to drive in the new seal. Make sure the races and the seals go in straight.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 10-04-2003, 04:17 PM
lousailor's Avatar
Do you have to put in new races if you're changing the bearings? The races look fine and smooth, and the bearings don't look bad either, but I already have a new set so I thought I'd use them since I had everything apart anyway.
Louie
'76 924 - Long Gone
- Mario Andretti
Old 10-04-2003, 06:56 PM
speed's Avatar
usually races and bearing sets are a match set...
1985.1 944n/a
Old 10-04-2003, 11:06 PM
SoCal Driver's Avatar
Always replace the seals.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 10-05-2003, 10:26 AM
