Send a message via Yahoo to asudds
Where is the Heater Fan Resistor Pack??
Just need to know where to look... Fan running only on high and not the other speeds... Likely this is the problem I just need to find it.
It is a late 944 with the auto climate controls
Aaron
Old 11-28-2003, 08:13 PM
AFJuvat's Avatar
Look under the black plastic cover on the blower fan.
You will see a cable attached to an oval shaped piece held in with two screws. - disconnect the cable and remove the screws - voila - one resistor pack.
Hint: soak the resistor pack in white vinegar - it removes the corrosion - if the resistor isn't too far gone, it will bring it back from the dead.
Resistor pack is a dealer only part - they run about $174.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-28-2003, 08:17 PM
SoCal Driver's Avatar
Gads! $174...
A $5 SCR is looking real good.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 11-28-2003, 08:49 PM
