jwolk1's Avatar
Unhappy Which relay controls the passenger side fan?
My passenger side fan is not working, however, the driver's side fan does (turns on when AC is turned on, and when engine is hot and AC is off). The motor is fine in the passenger fan, so I am trying to figure out which relay controls the passenger side fan? Thanks -
Jeremy
1983 Guards Red
Old 08-09-2001, 02:42 PM
Ehab's Avatar
Post
As I said, one relay, one switch, both fans should work identically.
Old 08-09-2001, 03:51 PM
Mike B's Avatar
Post
I would check your Thermo switch...The switch is located on the driver's side of the rad near the top on 924's...has two wires going to it...I assume the 944 has a similar switch...It is easy to check to see if it is good or bad (look in your haynes manual)...
I just changed a bad one today and the passenger fan kicks in now
Old 08-09-2001, 04:27 PM
