Small metal cylinder
on back of airbox two electrical connections vacuum hose in, vacuum hose out. ?????????????? #2 Is the wire ground closest to the tower or the manifold?
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Valve for the charcoal gas fumes filter canister.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
No, that's the A/C "extra air in to compensate for the drag of the A/C belt thingy".
*Disclaimer: The person above is actually dumber than he appears. my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements '84 944 auto/ps/ac/cc '86 951 Providing ignorance one post at a time. |
"extra air in to compensate for the drag of the A/C belt when you turn the A/C on thingy" I mean. I'm assuming that the car came out with A/C.
Yes indeed ----A/C a must in Florida.
So......If it wasn't working I would get a significant rpm drop at idle when the a/c cycles on... Yes...... Ground closest to the shocktower?
Oh yeh Todwic....I assume A/C comes standard in the 3rd plane of hades.
......If you know the right people.
aye, rpm drop. If one of em is brown, that's the ground, other than that, I can't really say. Get jiggy w/ voltmeter.
aye, standard. I keep hoping they kick me out for opening up the ice water stand, but I musta been really, really bad.
I was thinking to far back.
Auxiliary Air Solenoid. Energized when the A/C compressor clutch is energized. Allows additional airflow into the intake to compensate for the additional mechanical load from the A/C compressor.
Cliff Hipsher '87 944 India Red '86 951 Kalahari Metallic |
reading the subject line, i just got the theme song for 'will it float' stuck in my head. heh
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit |
New P Jargon from this post..
"extra air in to compensate for the drag of the A/C belt when you turn the A/C on thingy" = Auxiliary Air Solenoid both work for me
