Knock Sensor???
Is there a easy way to tell if my 1987 Porsche 924S has a knock sensor. I heard that some have 2 of them and others have 1. Was there a a specific year for the knock sensors. Also how far can the computer retard the timming 2, 4, 6, degrees??? Thanx
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
That is for the turbos and the 944S. The 944S, dual over head cams, has two and a hall sensor on the cam gear for figuring out which cylinder is predetonating -- knocking. Same with the 968's. Consider your self lucky.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
so the 924S has no knock sensors?
Correct, the 924S has no knock sensors.
Seem to recall reading that the 944S can retard up to 12 - 15 degrees. Dme is supposed to detect a knock, retard that cylinder a few degrees then listen again. No knock - start advancing timing again, if knock continues, retard and repeat cycle. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Dam I was kinda hoping that it had one. See I didnt want to add a timming controler when I install the nitrous kit. Right now I have a zex nitrous kit on my 2000 toyota tacoma and it made it alot easier because it has knock sensors so it will automaticly retard the timming. I think a 75hp shot is like a 4 degree retard in timming. But anyway back to the drawing board
The turbo has one. Don't know how it integrates into the electronics.
I want to Nitrous my 944.
(off the road due to blown tranny) Just wondering how those two statements can be in one post.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
It's only money. Some have more. The rest of us a lot less.
Thread Tools | |
Rate This Thread | |
