fast924S's Avatar
Send a message via AIM to fast924S
Thumbs down rear hatch problem
OK I have been play with the rear latch release and its driving me crazy. Ever since I have had the car I have always been unable to open the rear hatch using the button that is inside the car. If you push the button I can her the motor but it will only release one side of the hatch the other side is aloways stuck. I check the cables all looks good. I also lubed the latches and that didnt do it. Any Ideas???
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 12-30-2003, 09:03 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Adjust the hatch pins, one of them is too far out, it latches too early, so when the release goes, it pops the one, then it releases the pressure on the weatherstripping, and there is nothing pulling the hatch up.
I had the same problem on mine.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-30-2003, 09:08 PM
SoCal Driver's Avatar
The catch could also be out of alignment. With the hatch closed loosen the two nuts on each, wiggle the hatch a bit them tighten the nuts. Yes you have to do this laying down in the back.
While you are still there have some one operate the remote release and watch the two rods that go to each catch. Also look at the single rod that comes off of the release motor. This may need adjusting to get the proper throw.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-30-2003, 10:31 PM
Let's go shooting.
Dark Skies's Avatar
Also - inspect the condition of the pins themselves. The alloy heads often develop indentations that catch on the holding mechanism causing them to hang up whilst attempting to release.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 12-31-2003, 12:41 AM
1) If your hatch shocks - you know those dealies that lift he lid - are weak it won't lift enough to release.
2) I gave up on my electric release and added a manual release via a choke cable type deal mounted on the hump to the right of the rear of the drivers seat.
Old 01-02-2004, 06:09 PM
Zero10's Avatar
If the hatch pins are properly adjusted, the pressure on the weather-stripping should be enough to pop the hatch up just a little, so you can pull it up.
Buy my parts!
Old 01-03-2004, 12:11 AM
Autobahn Garage
Also check to see if your glass has seperated from the frame, This will make it hard to open as well
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 01-03-2004, 12:46 AM
