seaboltman's Avatar
Headlight problem
Ok well, i went to change my lights to new H4 lights. Forgot to turn off my headlights while i put the new one in (if it matters). So i put the new one in and it dosent work...Ok so i put the old one in, dosent work. This is what i know
1) fuse is fine, the head lights are on different fuses, and i checked them both.
Any ideas?
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 01-07-2004, 04:24 PM
SoCal Driver's Avatar
Broken wires or the socket connector at the plug is dirty and/or bent.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-07-2004, 04:27 PM
seaboltman's Avatar
ok well me and my dad tried to test if there was power to the fuse, dosent seem like there is, anyone have any ideas?
Old 01-08-2004, 01:36 PM
seaboltman's Avatar
ya, key is turned. The other headlight is on while we are testing this.
Old 01-08-2004, 01:41 PM
seaboltman's Avatar
alright well apparently "main beam" isnt the head lights. I had checked the wrong fuse. The fuse was actaully blown. i cut the connector off, leaving almost no spare wire to reconnect, and now i need a new connector *crys* ill i just go get one from this guy up the road. thanks for the help
Old 01-08-2004, 02:29 PM
seaboltman,
Check the wiring harness where it attaches to the headlight frame. I had similiar issues w/ the headlight blowing fuses and it seems as the lights rotate up and down the harness eventually wears and shorts. You might have to remove the wire tie in this area to see the wear on the wire jacket. Hopefully the problem is as obvious as mine was. If So just peel back the harness jacket and use 3cents worth of electrical tape to properly insulate. good luck
Old 01-22-2004, 11:39 AM
Official Sponsor
vital-transform's Avatar
my wires did the same thing, will get stuck with brites only
1988 - 924S Guards red, auto trans
Old 02-10-2004, 10:56 PM
