Ven Ven is offline
Angry Fuel level sending unit ! Something odd
Ok, Thought I was in for a quick fix today. My gas guage was stuck on R due to me taking an on ramp at 80mph. I pulled out the sending unit and shook on it a bit until the float started to move around a bit droped it back in the tank "put out my smoke" pluged it ut and nothing still stuck on R. The I took it out pluged it up and watched the fuel guage go up and down. Put it back in the tank and nada still on R. Well I guess I need to break down and buy a new one.
Old 09-09-2001, 06:58 PM
stray15's Avatar
Send a message via AIM to stray15
Post
Bummer dude. Where is the sending unit located?
Porsche, through and through
Tim
'83 944
My Photo Page
My Home Page
Old 09-09-2001, 07:15 PM
Post
Could you see if the guage was changing while you moved the float up & down?
drew1
Old 09-10-2001, 04:41 AM
Ven Ven is offline
Post
Yeah I could see the guage move up and down when I was messing with it outside the gas tank.
the sending unit is located under the hatchback carpet. Look for a white fuzzy pad silver on the bottom and sticky. Under that is a black rubber cover. Pry it off and under that is the top of the sending unit.
There is a bit of technical documentation about removing this unit on this site but it is for a 911 and WAY off when working on a 85/2 and later.
Old 09-10-2001, 04:46 PM
Maciek
Guest
Posts: n/a
Post
Hey,
I had to replace my sending unit too. They run about $120 bucks and are very easy to install. Good luck with it!
Maciek
Old 09-11-2001, 02:15 PM
