944S temp control fuse keeps blowing
Help! My 1987 944S keeps blowing a fuse. The dial that controls the interior temp. and well as the 2 sliders that control where air is directed don't work when this fuse pops. It seems to happen when I try to turn the A/C on--which now doesn't blow cold either. Maybe the fuse blows when the A/C compressor turns on? A new 7.5 fuse lasts no more than a minute. I'm out of fuses and ideas... any suggestions?
Thanks...
Old 02-23-2004, 07:00 PM
AFJuvat's Avatar
You have a short somewhere in your HVAC system (most likely the AC system.)
This can be a tricky one to troubleshoot. Which fuse is blowing?
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 02-23-2004, 07:11 PM
it's a 7.5 fuse in slot #29 in the fuse box. It's labeled Heating and Air Conditioning.
Thanks!
Old 02-23-2004, 07:28 PM
I have the same proble with a 85.5 that I take care of.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 02-23-2004, 07:35 PM
mhariush's Avatar
Hey guys,
Did you ever figure this out? I have an 87 S with a new compressor that does the same thing, and I have three different control units and they all blow the fuse when the AC button is activated.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-25-2012, 07:01 PM
mhariush's Avatar
fyi, been trying to troubleshoot this problem, no luck, but I swapped out the 7.5 fuse with a 10 fuse and it hasn't popped yet and the ac works great. Still trying to find the real problem so if any has any leads let me know.
thanks
Old 05-22-2012, 10:31 PM
It is the magnetic coil in the compressor. It can be changed out with the compressor in the car. If you un-plug the elec connector on the compressor, and read the resistance across the coil, it will be too low. This causes a high amp draw when you apply voltage to the coil.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
Old 05-23-2012, 05:27 AM
