Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
5 Speed Noise
Are the 5 speed trannys somewhat known to be a little noisy in 1st and 2nd? Maybe even 3rd?
'86 944, 5 Speed (Daily Driver)
Old 02-27-2004, 06:17 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
mine is on deceleration. the higher the gear, the less noisy it is
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 02-27-2004, 07:59 AM
fast924S's Avatar
Send a message via AIM to fast924S
It might be your diff getting ready to blow, Check your tranny oil!
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 02-27-2004, 10:45 AM
MixMasterK's Avatar
I'm going to be changing the fluid in the tranny this weekend. I have a gallon of Sweepco.
Old 02-27-2004, 02:49 PM
..P ..P is offline
The recommended transmission lube is AMSOIL Series 2000 75W90
It made a huge difference in the way my high milage transaxle sounded and shifted. I think it is far superior to Swepco. If you've changed to Swepco already, I'd still change to AMSOIL, because it made a huge difference in the way mine sounded and shifts.
regards, P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 02-28-2004, 08:50 PM
MixMasterK's Avatar
Hmmm..... I'll keep that in mind. I may as well use the stuff I got. At least if not to flush the other crap out of it. Don't know when the fluid was changed last.
Old 02-28-2004, 08:52 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
re: "diff getting ready to blow" is this common with 944s? I'm still "getting to know" my car and now that I've rearranged the hatch seal so it does sort of what it's supposed to with the resultant decrease in wind noise, I can hear a lot of R&P whine in 4th and 5th - definitely road speed related not engine speed. Please tell me they can whine and not mean anything bad!
I did just change my oil with Redline MTL, the old gear oil looked clean but was awful thick and did have a little bit of sparkle to it.
thanks
nate
1988 944... and a bunch of other cars
Old 02-29-2004, 03:47 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
Toolboy, get that redline out. I don't remember why you're not supposed to run it, but I know there's a really good reason not to use it (I THINK it's the wrong formula to use, thus meaning it will ruin the tranny). The entire transaxle on the 944 series is weak, ESPECIALLY THE DIFFERENTIAL! Do NOT launch the car (it's not a matter of if you'll destroy the R&P, it's when). The actual diff is quite easy to destroy as well. I know that when I demolished mine I had: one cracked spider tooth, one chipped spider tooth, broken the differential carrier in half (yes, the entire diff was in 2 peices), and i cracked the R&P. So be careful!!!
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 02-29-2004, 06:16 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
i have an '84 na and i would like to change the transmission fluid, it has an LSD transmission, where can i get the amsoil fluid and what kind should i use with my LSD transmission?
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 02-29-2004, 07:03 PM
fast924S's Avatar
I too have blown my diff 3 times!!!! Its starting to get old, I wish someone had a kit or something to make it stronger
Old 02-29-2004, 07:45 PM
