replacing rotor
dumb question... I just replaced plugs, plug wires and distributor on my early 85 n/a. by looking at the new rotor i can see a hole in the shaft that i assume is screws the rotor onto the shaft. problem is the old rotor is situated so that that hole is on the bottom and I can't see what kind of screw is holding it on. is it a small regular slotted screw, a hex, or what???
early 85 944 na
My water cooled flat six is in my motorcycle...
Old 02-28-2004, 03:17 PM
SoCal Driver's Avatar
Did the rotor come with a metal sleeve glued into it?
You can get some one to bump the starter while you are looking at the rotor.
There is an allen head (socket head) screw. Can't remeber the size. 4mm comes to mind.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-28-2004, 06:53 PM
Yes, there is a metal sleeve inside the shaft of the rotor assembly. The threaded hole goes thru the plastic outer skin and the metal sleave. I suspect you're right about the allen head because I couldn't get a flat blade screw driver on it. By the way my 13 yr old daughter came up with a great idea - hold a mirror under the rotor...
Thanks for your help.
early 85 944 na
Old 02-29-2004, 09:44 AM
Don't drop the screw. Also make sure it is tight. Some put locktite on it.
Old 02-29-2004, 02:29 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
Here's a thought: rotate the engine untill the bolt/screw is on top.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 02-29-2004, 03:01 PM
I put the distributor back on, turn the engine over, turned it off, removed distributor and the bolt for the rotor was at 2:00 oclock. a little dumb luck. thanks for your help.
early 85 944 na
Old 03-01-2004, 07:23 AM
Leave the dist cap off. Use a ratchet and socket on the center bolt inside the crank pulley. Turn engine clock wise.
Note: You might need a short extension to reach the large bolt if you have power steering.
Old 03-01-2004, 07:36 AM
Stop fronting.
ntrylvl's Avatar
Send a message via AIM to ntrylvl Send a message via Skype™ to ntrylvl
Another quick suggestion for anyone who encounters this problem: use a small mirror, which you can place beneath the rotor, to see exactly where you need to put your hex wrench. I've used this method, and it works!
Chris Harrell
'72 914 1.7 Saturn Yellow, '73 911T-RS Coupe Red
Old 03-01-2004, 08:05 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Be super careful when removing that screw. You don't want to strip it...
It's supposed to be 3mm, but they were made a little large (or so I hear). 4mm wouldn't fit on mine, but 1/8" worked like a charm.
If 3mm is loose, don't even try it, it probably has locktite on it. Very tight... flexed my allen key about 50* trying to get it free (I thought the allen key would snap...). Just go up to the 1/8" if it fits.
On mine, after I removed the screw, the rotor was stuck on. I ended up prying it off with a flathead screwdriver, although the rotor itself shattered, the sleeve still had to be pryed off.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 03-01-2004, 10:45 PM
