timing belt question
I am going to attempt to change my timing belt for the first time on my 83 944. Would anyone happen to have a list of parts that I would need to replace. Even unrelated parts that should be replaced, like the water pump. It has 185k miles and still runs great. Any links or any other information about this job would also be great.
Thank, Dave |
Not 185k miles on the timing belts????
Take a look at the full parts kits here at Pelican. Add a flywheel lock to it. If the seals are leaking then add the pin spanner to it as well as the seals. Many have reported acceptable tensioning using the Krikt tension gauge.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
IMHO...
![]() Yeah, with a 185k I'd replace the water pump. You are already in there, so go ahead and do it now. You'll need water pump, gasket, and new thermostat. To remove the thermostat, you'll need some heavy duty retaining pin pliers, with the straight, or slightly bent tips. (90 deg tips won't work.) Everything SoCal said. If you do replace the Balance Shaft Seals, be careful, the upper and lower seals are unique, don't mix them up. Good Luck JM |
LOL, yes, very heavy duty snap ring pliers!!
I had a 90 degree pair, and I gave them a little bend, so they were about 60 degree. Then I tried to remove the snap ring, and both arms of the pliers bent out!! Very stiff ring. Quick question, where do the gaskets go on the thermostat? Mine came with 2, a thick one and a thin one, slightly different diameters too. The one that came out was the wrong one, waaay too big, and was crushed around the thermostat itself. Very ugly fit.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
Last thermostat I put in had a U shaped gasket that went around the rim. Otherwise a gasket goes in before the thermostat.
I have a dedicated snap ring plier. No replaceable tips. Expensive but worth the lack of agrivation.
Official Sponsor
not really a related question but here goes...I plan to change my thermostat as well...what is the best one to use? part # / Temp and all that?
1988 - 924S Guards red, auto trans |
Feelin' Solexy
When I replaced my pump I bought a "kit" that included all of the nuts and bolts for the pump, the pump gasket, and a new thermostat.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 1995 Toyota Land Cruiser, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Thanks for the info guys
'83 944 |
All that said above plus the oil cooler seal kit and front seal kit.
I purchased a rebuilt waterpump that came with the thermostat installed from those "V" guys in Miami. Do you have any leaking at the oil pan? if yes add that to the list. If you are taking the machine down and gonna get dirty anyway might as well do it at the same time and check the motor mounts while under there. Rick
'83 944 "Guards Red" New Everything (seems like) 16" 968 Wheels has never left garage (yet) |
meister member
Do the '83's need the 24 or 27 mm wrench to adjust the tensioners?
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) Last edited by speedracing944; 03-05-2004 at 07:57 PM.. |
Mine are dedicated snap ring pliers.. Well, now they're bent pretty bad.
My thermostat came with 2 gaskets... from the looks of the pics in the PET, there are 2 gaskets on it? On an 83... that depends when they were last replaced. They could be either.
