Originally Posted by whitesmile View Post
R985, Minor mods required.
Wouldn't the Jumo 211 be more appropriate for a German car? I hear that slight uprating of the front suspension may be required. And perhaps some modification to the firewall, relocating it a meter or so backwards.
Old 09-27-2011, 12:46 PM
Back to the original question....
It's fairly straightforward, remove the DME/fuel pump relay and the spark plugs then test each cylinder (a google search will throw up the procedure).
One tip I'd give you is to make sure your tester has flats for a wrench on the end that you're going to screw into the plug hole. The first time I did a compression test on my car I didn't use the adapter for deep-set plugs and promptly got the tester stuck. Took me a while with a pair of needle nose pliers to get it out again. On the plus side, I'll not do that again.
hopefully you'll get consistent readings from all cylinders.
Mike
1986 924S, Maraschino Red, Spax adjustable dampers, no air box lid. part way through interior swap. Lots of issues sorted, plenty more to do.
1986 924S, White, donor car, part way through disassembly.
Old 09-27-2011, 01:06 PM
