Don 944 LA's Avatar
ground on a 3 wire O2 sensor ????
Probably a stupid question but am I correct ????
on a 3 wire O2 sensor (wire-1) heater ; (wire-2) signal ; (wire-3) common ground for heater and signal.
The reason I ask is does a 3 wire use the exhaust system as the ground for the signal to the DME.
If so, is there any ground spot for the exhaust.
Thanks again
1984/85 944na
Kalahari Beige (gold) exterior / Black interior
Los Angeles / San Diego
Lookin for ideas etc...
Old 03-23-2004, 09:44 PM
the one wire is the O2 sig. Block is ground.
The other 2 wires are for the heater only.
It doesnt matter which is power or which is ground.
1988 951 Alpine White / Burgandy
Profec B spec II EBC,HomeBrew Chips, WideFire HG, Tial 38mm, Magnecor Wires, Koni Rears, Adj Rear Droplinks, Zeitronix WideBand.
Old 03-24-2004, 04:59 AM
A 3-wire sensor uses chassis ground through the exhaust system.
On your car there should be a rectangular two-wire "bullet" connector with one male, and one female "pole" somewhere in the vacinity of the O2 sensor signal connector. This connector is for the heater wires on the sensor.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 03-24-2004, 06:54 AM
