Chain tensioners should be changed as a matter of course every 75 - 90K miles in any case as they do eventually wear out. J pipe should be replaced at the same time as they tend to crack with age. Cracked J-pipe = low oil pressure to tensioner = tensioner failure = crashed valves. Oil galleys must be cleaned - a rifle brush from a gun cleaning kit works well. This includes removeing the plugs from the block, cleaning the tubes, and then treplacing the plugs. Noy being anal retentive - just trying to ensure that you are not doomed to failure before you even begin. AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Juvat, thank you very much!
Ok now...what is this J-pipe you guys are talking about? I am clueless. Is it an expensive part, and what purpose does it serve?
Sean '88 Porsche 944 '95 Volvo 940T Seal Beach, CA, USA |
The J pipe is the little tube that supplies oil to the chain tensioner.
Can't recall the price off the top of my head I don't think it is that expensive. AFJuvat
Listen to these guys I jusy put my whole (44s engine back together and ihad to make sure everything was corrected and replace. Everything there saying is correct. It's not the money issue it's to keep your Porsche from having this same problem twice.
