BAD O2 Sensor ????
With the O2 sensor disconnected and DVM connected...
It reads .003 Volts and fluctuates slightly as the spring in the AFM is moved... I wanted to test it before I changed the $#%^ O2 sensor. Also, where should the arm on the AFM be at Idle ??? and is this a good way to set it to spec. Thanks again for any info Don |
Do a search on this list about O2 sensors. Someone referenced a link about what the thing should read. Yours sounds very low to me by a couple of decimal points.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
Don....I never get tired of looknig at your avatar or whatever they call em.....
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
I was told by a Porsche shop that the O2 reads from 0 to 1 volts with normal at .5 volts. Check FRWilks site for more info on the O2 sensors.
*************************** '97 Saturn SL (tiny 1.9L bubble car) '98 Grand Prix GTP (4dr family car with a bite FOR SALE) '87 944S (Sold as a German engineerd money pit) '78 Chevy 4x4 (What I drive when everything else is broke) |
I was told by a porsche shop that normal was 0.5 volts on a 0 to 1 scale. Also check FR Wilks site for good info on O2 sensors.
here's ahint : right click on the image and select " set as desktop item " and you will ALWAYS have it to look at. I did get most of the info for the O2 sensor from FRWilks site. I bought a Ford Aerostar van O2 sensor. I've been trying all day to get the MF'er off. I do have the FQS in position 4. After I change the O2 sensor I'll put it back and try the Smog check again. The F'ed up part is I have a HUGE fixit ticket for registration etc... I can't get it registered till I pass the smog. I also replaced the DME Temp sensor. I should be covered now, I hope. Don |
Just a thought, but is the sensor hot when you are testing it?
If it hasn't warmed up yet, the readings will be very low.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury! Buy my parts! |
I left the heater connected and let it warm up considerably. Thanks for the input Don Oh by the way, I still don't have the damn thing off. I hit it many times with PB Blaster, lettin it sit overnight. I could see that the unit was starting to twist instead of coming off. Last edited by Don 944 LA; 04-08-2004 at 10:54 PM.. |
I used to be able to pull the error codes on my car by stepping on the gas (all the way down) for 2 seconds and turn the key to the on position. The check engine light would flash any error codes concerning defective items in the emission system, including the O2 sensor. I think the 944 Hanes manual might contain the emissions error codes, and whether or not the sensor is reporting full lean, full rich, or not reporting at all. Don't have my 951 anymore but it's worth a try.
92' 968 86' 951 |
You don't actually turn the car "ON"! you just turn the key to the "ON" position without engaging the starter. It's by design and it was a requirement that all US cars be equipped with some type of sequence that displays the error codes on the dash lights for emissions related items. It won't hurt your car since the key is off when you step on the gas, then just turn the key, WITHOUT engaging the starter, but turn it into the "ON' position.
It seems like you took it a little different than the way it's supposed to be done. Since this is Porsche site, I ASSumed everyone would be able to figure out what I was talking about without having to explain to Darrel and his other brother Darrel, not to actually "START" the car with the pedal to the metal! DUH!
92' 968 86' 951 |
You can only obtain the fault codes on certain cars that have a "check engine" light (CEL). 944s don't have one and the early "blink code" fault reader is a little bit more than totally useless. During the 1989 model year 944S2 and Turbo models were updated to use the diagnosis plug for the Bosch KTS300 (Hammer). While obtaining the codes for applicable vehicles with a CEL using the throttle pedal method does work (Second hand report as I've never used it as we have the diagnostic tools). Unless it can be confirmed that the fault exists and the code is correct, you are no further along actually diagnosing and repairing the fault.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
