How to remove Alpine CD Payer
I have to remove an Alpine CD Player in the 944, I took the Face/bezel off , but I cant seem to get it out.
Has anyone messed with an Alpine before?
Is a special tool required?
Dave
Current: 1973 914/4 project. FOR SALE
Old 05-17-2004, 08:47 AM
depends on how new it is. on the older ones i think there are DIN plugs, which are four small holes near the corners. you have to stick a bent coat hanger in to release the locking mechanism, then you can pull it out. on the newer ones there is a little plastic catch on the left and right sides, a small circular thing. you have to move it up and slide the unit out to get it past the catch, then repeat for the other side. if neither of these seems right, get the model number and look up the user manual on alpine's website (www.alpine.com). they'll definitely have the right info there.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 05-17-2004, 09:28 AM
It has the second set up.
Old 05-17-2004, 10:04 AM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
you need the "keys" to pull it out. stop by a circuit city or best buy and they could hook you up with what you need to pull it out... or you could go the ghetto way and use a hanger...
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 05-17-2004, 10:23 AM
got it out.
Thanks.
now on to pulling the clairion out of the other for the swap. Its different set up too.
Old 05-17-2004, 11:04 AM
