Burn the fire.
Brando's Avatar
A 'Where can i get' and my 924 update
This Tach?
What be the part number for it? Maybe my mechanic can get ahold of it. Oh yeah, i also suggest re-locating your tach to the middle gauge spot Mine will be there shortly after i re-wire some things.
Also, yesterday i drove the 924 over to my mechanic, who did a bit of tuning up (adjusted timing and idle throttle adjustments). Sounds a bit better. Also commended me on a job well done! Unfortunately, i replaced my turn-signal fuse and after starting the car smelt wires burning, and saw some smoke. Popped that right out. Looks like i'll be installing a cab harness this weekend. I'm soooooooo looking forward to that.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-21-2004, 11:21 AM
Don 944 LA's Avatar
As far as moving the tach placement to the middle position:
Think of this... are you a " 10 & 2 o'clock driver ". If you are then that may be usefull.
If you are a one hander ( Like me ), the tach is in a good visable spot. The upside down tach really is usefull.
I don't have a working speedometer, so I never even look there.
I have the GPS off to the right side to show my speed etc...
( You have seen it )
Just my $.02
Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 05-21-2004, 11:32 AM
