Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
is there a problem?
I'm trying to figure out here if there is something wrong with my car. Anyhow, here are the symptoms:
when the car has been sitting for a long time (6+ hours), and is started, it runs a little rough for the first minute or so. RPMs are as low as 750-800. If you rev the engine during this first minute, the engine stumbles a little bit, almost as if the necessary gas isn't getting to the engine. Once the engine warms for about a couple of minutes, the RPMs increase to about 900 and the engine smooths out and runs fine.
When driving on cooler, dryer days, the car has a VERY noticable performance advantage than hot and humid days. Driving the car at 12PM when it is muggy out and 12AM is like driving two different cars.
So... any ideas?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 06-15-2004, 07:27 AM
Send a message via AIM to TheCooler
O2 sensor possibly? Have you gotten emissions done yet? Uhm...maybe you wanna check the pressure in the fuel rail to make sure its fine also.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 06-15-2004, 07:39 AM
SoCal Driver's Avatar
Idle control valve.
Hot and muggy suggests to me that you have the A/C running.
I've always found a car to be a better performer after a wash and wax.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-15-2004, 07:55 AM
What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
When did you last do a tune up on your car? Check plugs, cap rotor and air filter. Little stuff first..
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 06-15-2004, 07:56 AM
Writer/Teacher
CJFusco's Avatar
SoCal - no, i don't have the AC running, i'd always rather have the sunroof off.
Gordon - I just changed the cap and rotor about a month ago, an oil change about a month and a half ago, air filter was "recharged" (K&N) about 3 months ago... new plugs were done last fall, and I have an extra set at my house, so i can replace them tomorrow if I want.
Cooler - I haven't had Emissions done yet because... well, I'm sure you've heard about all the trouble that CT has been having with their testing stations.
So how would I check if the idle control valve and/or O2 sensor were malfunctioning?
Old 06-15-2004, 10:21 AM
Texas944's Avatar
Usually when an idle air control valve is going out your car will want to stall when you pull up at a set of lights - not from starting - but with these Porsches, i have come to expect the opposite of normal - you can take it out and check to see if it is varnished up - clean it out with some carb cleaner. Same for the O2 sensor - take it out and soak it in carb cleaner overnight - blow it out real good with compressed air. I would tend to go with The Cooler and check fuel pressure - watch the gauge while someone cranks it to see what you are getting at the start.
Brett, Dallas, Texas (Originally from Sydney, Australia)
1986 944, Zermatt Silver / Black Leather
1994 Full size Blazer, Midnight Blue
1989 IROC, Arrest-me-Red
1966 Corvette Roadster 427 4spd, Silver / Black
DRIVE THEM LIKE YOU JUST STOLE THEM!
Old 06-15-2004, 10:34 AM
TCMdocs944's Avatar
I thought the O2 sensor was not supposed to be cleaned or cleanable without affecting its function?
83 944 white w/Boxster wheels
Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
Old 06-15-2004, 10:51 AM
Texas944's Avatar
when they cake up, sometimes they can be cleaned - you got about a 50/50 chance of it working (from experience)
Old 06-15-2004, 10:57 AM
Burn the fire.
Brando's Avatar
Possible: Your K&N air filter is pulling in ripe hot air off of the engine block. On cold days you would notice a difference. If you need a stock airbox i have one lying around.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 06-15-2004, 11:51 AM
AFJuvat's Avatar
For the stumbling problem - look for a leaking injector.
All of these cars like cooler and dryer days - air is denser with low humidity - perfect for a car.
Chack your air flow sensor - you may have a bad or fouled air temp sensor.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-15-2004, 07:46 PM
