Send a message via AIM to beagle113
sluggish speedometer
what would cause the speedo to read slower than what it should be until i quit accelerating. then it catches up to where it needs to be. it is on a 86 944 turbo.
Old 07-21-2004, 02:44 PM
Send a message via AIM to 944imraan
If you have the same cable speedo a lot of us do:
Did the square fitting in the back of the speedometer get stripped? That would cause this issue, though I haven't seen it happen. If the collar that holds the cable is not screwed down completely, that may also do it.
White 1985/1 944
--my first car
--limited slip differential
--cross drilled rotors
--omnimagnum high-energy ignition
--CB equipped
--laptop installed, seeking GPS chip
--keep the socks away from my car
Old 07-21-2004, 05:38 PM
i thought the 85/2 and up wasnt mechanical, but electric. i might be wrong.
Old 07-21-2004, 06:01 PM
I don't know--I've only worked on the cable ones.
White 1985/1 944
--my first car
--CB equipped
Old 07-22-2004, 12:32 PM
The 85/2 and newer speedometer (except for the 924S cars) are driven by an electric signal from the speedometer sender mounted on the transaxle.
If your speedo is sluggish, as you describe, the speedometer head needs to be serviced. There are several places that will charge you $100 to $150 to fix it.
gb
Good luck, George Beuselinck
Old 07-22-2004, 12:48 PM
If it goes to zero and back up sometimes then it is probably the impulse sender in the transaxle.
'86 Guards NA 70K- driving 11yrs
'98 Techno-Violet M3 57K- since 4/04
'55 MiG-15 UTI - Mach.97 -rebuilding
'58 Cessna 175 w/GO-300
'98 Scarab Sprint, 4.3V, 62mph
'92 Guards 968 (my girlfriend's)
Gone...
'82 Camaro Z28 1st car
'84 VW Rabbit Cabrio & GTI
'77 BMW 630 4spd sport bilstiens
'84 POS Cavalier- drove to junk yard
Old 07-22-2004, 01:33 PM
well, i might just need the whole cluster. the bar gauge reads wrong at times, the fuel gauge wont go to full when i fill it up, and if i hit the dash hard, the water temp will lower.
Old 07-22-2004, 02:01 PM
