winter-hater club member
nynor's Avatar
actually, at one time, and maybe they still do, porsche made a 911 motor for use in aircraft with timing gears, no chain, no belt. so it can be done, and it MUST be reliable.
"COOL PRIUS!" - Nobody Ever
Old 08-12-2004, 08:26 AM
jm951's Avatar
In some domestic V-8 set ups, the chain is eliminated with gearing. There are two main reasons for it- 1)it insures valve timing through eliminating any possibility of chain stretch and 2) eliminates the possibility of chain breakage because of forces generated by radical, high lift cams. As the engine rotates, the cam undergoes a series of "jolts" as the valves are actuated. If strong and frequent enough, these jolts can concievably damage a chain drive, hence the reliability for uses like aircraft.
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 08-12-2004, 08:42 AM
Mercedes has used chains in their aluminum engines for many years. The chain on my old 1980 450 is about 6 feet long. The engines are durable and there is no problem with thermal expansion and chains. My 1980 has 150K on it. The chain was replaced at 100K. This engine is far from a performance engine.
On the other hand my 400E has 32v and 4 cams. It is also chain driven with an aluminum block and heads. It could be considered a performance engine. It's redline is about 6K.
My 18v V-6 AMG supercharged MB also is aluminum with a chain drive. It is definitely a performance engine.
So I would tend to say that chains can be used with aluminum blocks.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-12-2004, 08:52 AM
jm951's Avatar
I'm not saying they can't, but how are the chains tensioned and what mechanisms are there to keep that tension constant?
Old 08-12-2004, 09:28 AM
Parrothead member
VINMAN's Avatar
There are chain driven valve trains that use spring loaded tensioners.
Vinny
Old 08-12-2004, 10:07 AM
Parrothead member
VINMAN's Avatar
also the amount of tension on the chain is such that the effect of thermal expansion would be miniscule.
Vinny
Old 08-12-2004, 10:09 AM
The old one uses springs, plastic sliders, and an oil pressure piston thing. I have never worked on the 3 and 4 valve engines so I don't know how they are arranged.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 08-12-2004, 10:37 AM
Don't forget about the need to oil the chain/gears. But this could be a good thing. Only the crank seal and timing chain cover gasket need to be replaced, when it starts leaking, instead of the 4 seals now.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 08-12-2004, 03:35 PM
