dj_yen's Avatar
Interference Engines
We on this forum should all be very well versed in the dangers of interference engines and the importance of regular timing belt changes but my question is, why an interference engine in the first place?
What is the advantage of an interference engine over a non-interference engine? Are they cheaper to make?
944 NA 5-spd, Red, 1987 - 2005
May She Rest in Peace
944 Turbo 5-spd, Black, 1987-present
70k miles
Old 08-04-2004, 12:35 PM
scheistermeiste's Avatar
Send a message via AIM to scheistermeiste Send a message via Yahoo to scheistermeiste
ive wondered that my self...
Special Edition 924S 1988 <- SOLD!
Asking if you should replace that timing belt is like asking if you should re-use a condom that may have in hole in it with a hooker.
Old 08-04-2004, 01:04 PM
jm951's Avatar
valve lift & duration v compression ratio
86 951- again on the road, but needing some more TLC
82 931- again among the rolling
"If yer paint aint chipped, you aint passin nobody."
Old 08-04-2004, 01:14 PM
True, but it also has lot to do with cylinder head design, valve location and angle and other fun stuff.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-04-2004, 01:29 PM
gearhead290's Avatar
Send a message via AIM to gearhead290
Maybe somebody at Porsche wanted to make sure that the mechanics keep busy and that Porsche makes some money off of selling the belts?
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 08-04-2004, 01:57 PM
Burn the fire.
Brando's Avatar
Not a worry for me! haha!
also, early 928 guys have 2x my engine... teehee, non interference!
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 08-04-2004, 02:38 PM
Super Moderator
nize's Avatar
from what i've read about this in the past, interference design allows greater piston movement which in turn allows for greater compression. and as we all know, more compression = more power.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 08-04-2004, 02:48 PM
Send a message via AIM to Makenzie71 Send a message via Yahoo to Makenzie71
^correct
http://forums.pelicanparts.com/uploa...1093905626.jpg
the "baby" that comes first...
Old 08-04-2004, 03:23 PM
Here's another good question, why did Porsche use a timing belt instead of a timing chain? This has kept me awake with headaches many of nights
Old 08-04-2004, 06:31 PM
Belts...though they wear faster...are cheaper and easier to deal with. Also, almost every aluminum head/engine uses a belt as opposed to a chain because of stress factors. A belt is elastic and will go with the stress on the mass of the head or block...a chain will not. Belts are also easier to change and maintain and inspect. The only obvious sign of wear a chain will show is rust, and loosening a tensioner is far easier than removing a cam or sprocket to change a chain. Belts are also quieter and smoother to operate which creates less wear on the engine's hard-parts (if you're a bike fan, this will make sense to you).
The biggest reason, however, is probably that pullies and belts are cheaper than sprockets and chains.
Old 08-04-2004, 06:41 PM
Super Moderator
nize's Avatar
i actually read about that one a while ago also. although a chain would make belt changes unnecessary, the added weight/resistance would make the motor less nimble and rob power. i suppose with modern technology they could design it better (i believe the honda s2000 has a chain timing belt) but we're talking about 20 years ago.
the real question is: why doesn't someone design a better belt, like out of graphite or steel-belted or some other higher-durability/longer-lasting material/design? i'm sure there's a market for an improved +60k mile lasting belt.
makenzie, you reading this? i know you're looking to fabricate some of your own parts to sell to other porsche owners, here's something you can make and sell that hasn't been done before (to my knowledge).
and if someone knows of such a belt, please let me know!
Old 08-04-2004, 06:42 PM
The belt question is more significant in my mind. How many non-interference perfromance engines are there?
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work.
Malo periculosam, libertatem quam quietam servitutem.
Old 08-04-2004, 06:45 PM
It's actually suggested that chains be changed as often on interference engines. Non-interfenrence engines usually make no reference to timing belt maintanance.
A radial timing belt would be the same as using a chain. The majoraty of th reasoning behind using a belt is it's elasticity.
Old 08-04-2004, 06:46 PM
4mE
5mE
6m-GE
6m-GTE
7m-GE/GTE
1jz-GE/GTE
1g-GE/GTE
2jz-GE/GTE
1zuf or whatever the V8 is
4A-GZE
4A-GE
4E-FTE
3S-GTE
12A
13B
13B-T
13B-REW
13B-REE
20B
20B-RE
26A
4G63T
RB20DET
RB25DET
SR20DET
CA18DET (I think)
(those are the only ones that pop into mind right now)
Old 08-04-2004, 06:51 PM
Super Moderator
nize's Avatar
the honda s2000 is a chain-driven interference engine.
recommended timing belt replacement on the s2000 is 90k miles.
Old 08-04-2004, 06:52 PM
Super Moderator
nize's Avatar
considering how tight the 944 timing belt needs to be, and how it needs to be tightened again after being driven a while, i doubt elasticity is the reason they used a belt.
if it wasn't as elastic, i'm guessing it probably wouldn't even need to be re-tightened after initial installation.
Old 08-04-2004, 06:56 PM
My area of expertise kinna starts fading around 1997. But, since it's an intereference engine, a routing changing of the timing assembly is still important and noted by the manufacturer.
MR2's, apparently DO have interference engines...not sure which ones yet.
Old 08-04-2004, 06:57 PM
When you consider the change in the block from heat being less than 1mm, there doesn't need to be much elasticity. That much change, however, could bind a chain easily.
Old 08-04-2004, 06:59 PM
Super Moderator
nize's Avatar
uh, we're not talking about chains, we're talking about a longer lasting +60k mile belt.
Old 08-04-2004, 07:03 PM
ok...I'll try it a different way...
The belt has give to it. A chain does not...because a chain is made out of metal. Adding steel will give the belt all of the qualities of a "chain".
Ever hear the phrase "only as strong as it's weakest link"?
Old 08-04-2004, 07:13 PM
