Driver
Dash light help
OK,
Here is a picture of the back of my gauge cluster.
The green lines point to the little lights that are OSRAM 12V 1.2W.
The red lines point to the 3 big light that go into the reflectors. They are OSRAM 12V 2W
Questions:
1. When I buy the bulbs, do they come in the plastic cups, or do I take the bulbs out and put new bulbs in those cups.
1a. Do these bulbs screw out or what, I can't get mine to move & am afraid of forving anything.
2. Where can I get direct replacemant for these bulbs, and what are they called.
3. What is the LED replacement for both the large & small bulbs? (this one is for Misty)
Thanks in advance. I do not know why I am so "bulb challenged".
GHEN
'87 944
Old 08-07-2004, 05:52 PM
AFJuvat's Avatar
Twist them to the left to remove them - they are sort of a bayonet fitting.
They come with the plastic fitting. No need to change the bulbs over.
Pelican sells them all as far as I know. Just be specific as to what you need.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 08-07-2004, 07:47 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
In my cluster (late - looks like what he's got) the big bulbs are 194 and the small ones are W1.2W. The replacements I got do *not* come with the plastic bases. Yes the feel tight but they do turn counterclosckwise maybe 90 degrees to remove.
good luck
nate
1988 944... and a bunch of other cars
Old 08-07-2004, 08:21 PM
Send a message via AIM to bluebullet
just to let you know as well..i tried putting blue bulbs in mine today..dim as hell...So if anyone is thinking about it dont do it. I couldnt even read my gauges. I guess I'll have to get LEDs put in.
1985 944 / 2007 335i / 1987 325is / 1985 535i / 1999 528iT / 2006 X5
Old 08-07-2004, 10:29 PM
http://www.superbrightleds.com/1157.htm
You need the wedge-base bulbs type 194/168 I think. As far as I can tell, they are NOT as bright as incandescents...But if you clean your light tunnels they should be fine (I assume). Plus, you'll only have to change them once. When I got mine they didn't come with the plastic fitting, but it was easy swap the bulbs. Good luck.
1983 944 with S2 motor, trans, suspension and exterior -- crunched parts car
1987 944 -- soon to be 1987 944S2
Old 08-08-2004, 11:04 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Wow, somebody that actually had success with those. I have seen them tried on 4 different occasions, and all times they were rated as fit for the pit.
For what it's worth, I've had a few really terrible experiences with those guys, and no longer order from them.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 08-08-2004, 06:48 PM
