Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
new bad noise
just when I thought I was getting the car pretty sorted out... started making a new, alarming noise. Whenever the A/C is on and the engine is at idle, I hear a noise that sounds an awful lot like a couple bolts rattling around in a coffee can. Can this be anything other than the A/C compressor or clutch? the A/C still works OK and the noise goes away immediately when I shut the A/C off.
How much $$$ am I looking at to repair? (hate to ask...)
nate
1988 944... and a bunch of other cars
Old 09-03-2004, 06:28 AM
AFJuvat's Avatar
Your clutch on your compressor is siezing up. and\or your compressor is tearing itself apart.
get a 12mm wrench on a socket and try to turn the compressor over - you should be able to hear the noise and\or feel resistance.
Either way, the parts are rather expensive.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 09-03-2004, 07:26 AM
also check your radiator fans, one could be locking up or there is something hitting them. They both come on when the AC is on.
86 951 Black on Black
Konis Yellow front, Orange back
Fast as hell
87 944 na
66 Skylark ( in parts )
750 Honda Chopper (8 ' Looong)
800 Vulcan
02 Grand Prix GTP ( Wifes Car) also Fast as Hell
Old 09-03-2004, 07:54 AM
It could be the heat shield under the exhaust manifold. The shield can break close to the mounting points and cause it to rattle. Don't ask how I knew!
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 09-03-2004, 03:16 PM
ae1969's Avatar
Send a message via ICQ to ae1969
AFJuvat
Sorry to hijack ....but mine is starting to do the same........ can see some metal fillings...
Hard to believe I would want to turn it on with 50 degree weather......
No solution but a new compressor I take it.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-03-2004, 03:47 PM
Send a message via AIM to ike229
I know that this is a rather old post, but i have ran into the same problem.... It seems that the heat shield near the manifold has broke loose. I havent had the time to get in and pull it out to see exactly what is going on, but do know that it is indeed loose. It makes one hell of a rattle when the engine is started. When i do get the time, should i try to repair the shield... or would i be fine just pulling it out ?
Old 02-04-2005, 02:22 PM
This is a real pita to remove.
I had to break it into half by unbolting the two M6 hex bolts holding the two together from under the car.
Then remove the shields from the block with those two M6 allen socket head bolts. Another pita.
Then try to get one section out through the manifold and the other one through the oil filter section with the oil filter removed.
I managed to weld the broken tabs using a mig welder.
Then go through another session of difficult maneuvering to install.
Good luck and have a lot of patience
Old 02-04-2005, 03:42 PM
So would it be a bad idea to remove them... and not reinstall ?
'05 M3 - Alpine White
'88 924S - Black
'91 318IS - Alpine White
'88 Honda Hawk
'75 Honda CB360
Old 02-04-2005, 04:15 PM
Yes, it would be a bad idea to remove it.
It shields the heater hose, heater valve, balance shaft seals and the passenger side engine mount in a way from exhaust heat.
That's why I fixed it and put it back.
Old 02-04-2005, 04:22 PM
