Early oxygen sensor installation
I just installed a new O2 sensor on my 83.
7/8ths long handled wrench. $20 universal one-wire o2 sensor from bosch Warmed car up Put on ramps Twisted old sensor off easily Cut old wire Crimped and heatshrunk new wire on Tightened her in Done deal.. That had to be the easiest job I have ever done on the early...sorry for you late and 951 guys. Early guys....GET ON OUT THERE AND CHANGE THOSE O2 SENSORS!!
83 944 white w/Boxster wheels Planned mods- custom leather interior, 968 antenna, soundsystem, 968 style rockers, clear sidemarkers
BTW- car ran a little rough for the first few minutes post o2.
THEN My stumble at 3300-4300 under load is GONE.....?????? With all my research I have yet to hear that one. I will have to drive tommorow more and see if it is really true.
I'll second the easiness of the O2 sensor installation - at least until my only cigarette lighter i was using for the heat shrink run out of gas and i had to use matches which kept on blowing out in the wind - hrmph!
Andy Lowered '84 944 no longer smokin! Lowered, adjustable KONI shocks, APE chip, K&N panel filter, Strut tower brace, Blue Fuchs (+ anything else i've not discovered yet!) http://photos.yahoo.com/shineyblue944 |
Do they carry that at autozone or some place similar?
1984 944 N/A 1996 Golf Gl Drive fast. Take chances. If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields |
Yes. I got mine from pepboys but the local autozone carries them as well.
I got mine from Kragen - Bosch 11027 for my non-California car. The non-Ca cars have just a single wire and the Ca cars have three - it will be worth having a quick look down at the exhaust pipe from under the hood to see which one you need before you buy one.
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESULTS&MfrCode=BOS&MfrPartNumber=11027&PartType=291&PTSet=C
