Porsche Crest speedometer issue!
My speedometer is currently not working on my 84 944, any easy fix or does the whole assembly have to come out of the dash?
Old 11-10-2004, 08:35 PM
seaboltman's Avatar
i cant tell you whats wrong, but i know there has been many a thread started about this same thing. Use the search button and search for "Broken speedometer" and you should find what you are after.
Good luck
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 11-10-2004, 08:57 PM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
Mike, you should put your year/model of the car in your signature too.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 11-10-2004, 09:22 PM
winter-hater club member
nynor's Avatar
the whole assembly has to come out of the dash...
i just pulled mine out about 2 weeks ago. let me know if you need more specific help.
"COOL PRIUS!" - Nobody Ever
Old 11-11-2004, 06:18 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
Just drive by the sweet sound of the engine.
The speedometer on the 84's gets its reading from the driver's side wheel.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Old 11-11-2004, 07:48 AM
That Guy
Techno Duck's Avatar
As was mentioned, the speedometer cable is broken likley. The cabel plugs into the back of the speedo gauge, through the firewall, loops in the engine bay to the left front hub. Pull the wheel off, pry off the dustcap. Use a hex key to remove the clamp. Pull out the cable from the back of the hub. Tape the new cable to the old cable to help fish it through the firewall. You will have an easier time removing the steering wheel with a 24mm socket. Push the speedo gauge fowards by reaching under the dash. Pull the old cable out and reconnect the new to the gauge.
Also make sure you have a circlip to secure the cable to the hub.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-11-2004, 02:34 PM
On the early cars, like everyone here has stated, it is most likely a broken cable.
86 944 daughters
88 944 step-sons
07 Ranger 4x4
I have tons of spare parts, let me know what you need.
Old 11-11-2004, 05:19 PM
