MORE problems - dash lights don't work
Turned the car on, turned my lights on out of habit, and no gauge/climate control/etc lights.. What could have happened? I checked the "Instruments" fuse, it's good.. What the hell could have happened? They worked fine the other ngiht..
Turn the knob on the lower front of the dash that dims the dash lights. Can't recall if it's on the right or left of the steering column.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Check the dimmer first.
If no go, check the positive wires from the battery - make sure they are all connected and tight, otherwise, it would be your Ignition switch AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
Tried dimmer.. nothing. Will check wiring tommorow..
Could be a short in the circuit board on the back of the instrument cluster. This was recently covered here & on the Rennlist 944 forum. Do a seach on dash and Z-man - should get you there.
-Z.
2010 Cayman S - 12-2020 - 2014 MINI Cooper S Coupe - 05-17 - 05-21 1989 944S2 - 06-01 - 01-14 Carpe Viam. <>< |
Thanks man I'll do that right now.
