kgelles's Avatar
Smile Run engine without AC/PS belts
Can you run the engine with the front belt cover off (along with the power steering and ac belts) in order to inspect timing and balance belt operation? What are the clearances of the balance belt idler roller with the lower balance belt sprocket and the belt above it?
1985.5 944 NA
Old 01-06-2005, 01:32 PM
Macfreak007's Avatar
Send a message via AIM to Macfreak007
yes, you can run the car with out the front cover, but I would caution you to take the back cover off as well, as this is what keeps the whole thing from rubbing the belts. Also the AC belt is the same one that drives the alternator so you would need to get a different size belt or something.
'84 944na -- Sold
'84 944na -- Sold
'85 944na, -- Sold
Old 01-06-2005, 01:39 PM
You won't see anything with the cover off and the engine running.
Either the belts need replacing or adjusting. Check the service history.
I usually run the engine for a few minutes after changing the timing belts to make sure everything is good, running with the alternator belt off for that short length of time doesn't make any difference.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-06-2005, 01:58 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I've heard of someone slipping a greatly shortened belt over just the crank pulley & alternator to bypass the a/c compressor (IIRC it had a busted bracket or something) but it's a real PITA. I tried to do this on my 951 a while back since my a/c compressor clutch / pulley was bad and siezing up and snapping belts. Long story short, you can't really do it since the alternator doesn't have any "swivel" or adjustment capability - this is incorporated into the a/c compressor by means of the adjuster rod so if the compressor is the problem, you're hosed until you fix it.
Like I said, someone told me it COULD be done, but I'm sure it ain't easy since you're trying to stretch a belt over two more-or-less immovable pulleys. . .
Black Cars Matter
Old 01-06-2005, 05:25 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I don't have p/s belts on either of my cars. I also have the front cover off on my '84, but I wouldn't recomend it. Though I think it would reduce the chances of a busted balance shaft belt wrapping around you cam belt, it also opens that precious belt to all the elements found inside of an engine compartment.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 01-07-2005, 05:32 AM
kgelles's Avatar
Thanks. Idid manage to start the engine for a minute or so with the cover off and the power steering and alternoator belts off. The battery was able to run the engine for this period during which I was able to listen for any starnge noises coming from any pulleys or belts. Everything was fine and I put the cover back on and reinstalled all of the belts. By the way, in case anyone looks at this thread for the idler roller specs- I found out the balance belt idler roller should have 0.5mm clearance on the lower part of the roller and the belt underneath and should JUST touch the belt above. It should NOT interfere with the straigtline running of the belt above whetre it touches. Everything is running fine. Thank for the help.
1985.5 944 NA
Old 01-08-2005, 12:17 PM
Actually, the belt idler adjustment specification shows that it SHOULD alter the straight line of the belt.
The 0.5mm clearance on the lower run of the belt is correct.
Old 01-08-2005, 12:46 PM
kgelles's Avatar
Thanks. Do you know the specifications of how much it should "push" into the belt?
1985.5 944 NA
Old 01-08-2005, 05:57 PM
