Official Sponsor
vital-transform's Avatar
rear window defroster
my rear window defroster has stopped working although the mirrors work fine the elements at the rear window do not get hot at all??
anybody seen this before?
1988 - 924S Guards red, auto trans
Old 01-16-2005, 05:17 PM
vott does ziss do?
ronin's Avatar
yes. check the wires running from the rear hatch struts to the element on the glass
Old 01-16-2005, 06:19 PM
livewirevoodoo's Avatar
courtesy of clarks-garage.com:
Troubleshooting Rear Hatch Defroster
the haynes manual, if i recall, also had a page or two devoted to it..
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 01-16-2005, 07:00 PM
entertaining the idea
UconnTim97's Avatar
Mine does that from time to time. The wires along the struts come loose, just as Ronin said.
There are some who call me... 'Tim'.
a well set-up 1983 Guards Red 944
Old 01-16-2005, 07:22 PM
Official Sponsor
I'll have a look at those wires..I am assuming that the fuse will be for both the mirrors and the defroster?
Old 01-16-2005, 08:54 PM
SoCal Driver's Avatar
A few things that Clarks does not cover:
All of the voltage for the rear window heating element comes in on the drivers side wire. The wire on the passenger side is for the interior cargo light.
The heating element is grounded through the passenger side gas spring strut where it connects to the body. This is why there are two different part numbers for the rear window/hatch struts.
The round thing at the car end on the car side of the passenger hatch strut is the contact switch for the rear cargo light.
If the bent copper contacts pull off of the heater grid you can solder them back on. Use a hot iron and do it quickly.
In most cases it's the slip on connector on the drivers side that you will have problems with. The wire breaks or pulls out of the connector. Sometimes the contact that rubs the strut rod on the passenger side is bent -- not making contact.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-16-2005, 09:19 PM
Official Sponsor
the pass side contact thing I can see visually is definately not making contact...I'll start there
come to think of It haven't seen the cargo light working lately I'll check that while I'm at it!
Thanks guys
Old 01-16-2005, 09:29 PM
Don't confuse the cargo light switch thing with the contact for the rear heater grid. The cargo light contact closes when the hatch is opened.
Old 01-17-2005, 09:20 AM
Official Sponsor
gracias
Old 01-30-2005, 09:27 AM
Send a message via AIM to TurboFoFo
wonderful info, i've been having the same problem. thanks guys.
PCA Member
86 951 Blk/Blk
Guru Chips, Momo MonteCarlo Wheel, Kinesis 17" SuperCups
Old 02-01-2005, 10:27 AM
