Porsche Crest how do you know if you need ur belts need to be done
Hey
i am pretty sure that my belts were done about 20000 miles ago. How often do i need to do them and how can you tell if you do. my engine is giving off a little bit of a whinning sound that i think is coming from the fan or belt. Is it time for me to get new belts. if so where can i get the parts online at a decent cost, how much can i do myself, and how much is this going to cost me. I am not bad with cars and my dad is really good with em so if this is a do able project let me know and please post any how-to websites you may know of. thanks
black 1989 porsche 944
DRFT
Old 04-21-2005, 01:10 PM
seaboltman's Avatar
just tighten them a little, and the belt squeek should go away.
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 04-21-2005, 01:42 PM
Feelin' Solexy
Tishabet's Avatar
clarks-garage.com makes this procedure easy.
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 04-21-2005, 01:57 PM
how often do you need to change them
DRFT
Old 04-21-2005, 02:19 PM
SoCal Driver's Avatar
20 to 30 thousand, three years. Look for teeth spliting off of the belt. Or missing teeth. Bad tensioning pullies can lock up and strip teeth off of the belts. In most cases a broken balance belt will wrap up in the timing belt taking it out too.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 04-21-2005, 02:24 PM
Non Compos Mentis
I buy the parts here at Pelican.
Old 04-21-2005, 03:02 PM
auh auh is offline
auh's Avatar
Send a message via AIM to auh
I thought it was 60k between timing belt changes
1974 914 1.8 Sold...
1984 944 my baby...more of a pain in the @$$ than takin' it with a cucumber, but I still love it. THE CAR YOU PERVS!!!!!!!!!!!!
1990 Nissan 240sx fastback aka Japanese 944
Old 04-21-2005, 05:26 PM
meister member
speedracing944's Avatar
My belt schedule is replacement at 30K miles, retension at 1.5 K and 15K miles. Belts are cheap..... new valves and head work aren't.
I think Porsche recommends a 60K mile replacement with tensions at 1.5K and every 15K miles.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 04-21-2005, 05:45 PM
so all i need is timming belt. Thats like 50 bucks. I thought there was a lot more involed with this. what do you replace on these cars after every 30 to 40000 miles. I thought it was like a 1000 dollars worth of crap. Not just a 50 dollar belt. Am i missing something.
DRFT
Old 04-21-2005, 06:19 PM
Time and balance belt. Replace these as a set.
Pullies and rollers depend on their condition when you do the belts. Most just replace them as insurance. If you are familar with the sounds your car makes you just might be able to hear a bad pulley before it locks up. The bet is about $1500 IF your timing belt seperates and the valves get bent.
Old 04-21-2005, 08:29 PM
Did I show you guys I have a mod that takes care of the valve-bashing when you break a belt? Take a look at this:
I've come up with a cutting-tool and jig that bolts to the head-studs when you have the head off. Cuts the two reliefs to the proper depth. Gonna be available on a rental basis soon.
I still quite perplexed as to the durability of this timing-belt. On my previous Supra, I changed the belts every 125k-miles and it had to drive TWO cams nonetheless...
Old 04-22-2005, 02:10 AM
Parrothead member
VINMAN's Avatar
Danny, how many points does that drop the comp. ratio?
Vinny
Old 04-22-2005, 08:37 AM
Darn thick pistions-- I hope.
Old 04-22-2005, 11:45 AM
No. Thats the milage between valve jobs IF you don't replace your belts at 30,000 miles.
Old 04-22-2005, 11:49 AM
Changing the belts too soon makes more sense than attempting to extract every mile from a good looking belt, espcially if you like to wind it up when you drive it. My last belt change included some rollers which made the car exceptionally quiet..
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 04-24-2005, 05:15 AM
