Ornery Bastard
1986 951 questions about standard equipment.
I've heard some rumours about the '86 951's that I was wondering if anyone here could confirm or disprove.
Namely, I've heard that the '86 cars have forged rods rather than cast and that the 86's also had the transaxle cooler.
Are either of these true? And if the second is not true, then that leads to the question of did all the transaxles with the oil cooler have an LSD?
Thanks much!
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 06-18-2005, 11:56 AM
The oil cooler was part of the M030/758 "sport running gear option"
M758 was the oil cooler and LSD option. M220 was another LSD option.
It's possible to have had a non-lsd AOR trans with an oil cooler. The cooler was not listed as an option, which tends to mean either it was stock in certain circumstances or it wasn't. So anything is possible. Nearly all the late ROW 951 had one.
I can't answer the con-rod question, but will research.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 06-18-2005, 12:15 PM
Ornery Bastard
Thanks! That's what I love about this place. There's always someone with the answer.
Old 06-18-2005, 12:26 PM
AFAIK, forged con rods, LSD diff and an external oil cooler were standard equipment on '86 951s.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 06-18-2005, 04:32 PM
Ornery Bastard
This makes me happy.
Old 06-18-2005, 04:47 PM
LSDs were an M220 or M758 (40% locking) option on '86 951, not stock.
Oil coolers were much the same too.
Old 06-18-2005, 05:18 PM
Ornery Bastard
Thanks Britwrench! M758 is what I'll look for. I only knew to look for M220 and didn't know that the M758 included the LSD as well. Should have the 951 within the week.
Aaron
Old 06-18-2005, 05:27 PM
I stand corrected. My' 86 has both LSD and cooler, but I never checked the option codes, so I'm looking for either M758, or M220 on the sticker?
Cliff Hipsher
'87 944 India Red
Old 06-18-2005, 06:10 PM
ae1969's Avatar
Send a message via ICQ to ae1969
I have 4 trannies
86 951 - LSD and cooler
86 951 - NO LSD and Cooler
86 944 - Both with coolers.
I am pretty sure I read somewhere that all of the 86 models had cooler but differed in LSD and non-lsd.
The 86 has forged. There was some mixed information saying that the 86s were the only ones ...... but later I recall reading that all the turbos have the forged rods. Although the casting codes are different (hence the arguments). I am pretty sure that it was thought that the 87's did not have forged but I recall reading some info that the casting codes were different but in fact they were still forged.
The only NA's to have forged rods were the 83 and part of 84. As far as I recall.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 06-18-2005, 09:49 PM
Zero10's Avatar
Send a message via ICQ to Zero10
Not all 86's have the transmission cooler. My 86 NA didn't have it. It was an option as well, but since so many transmissions get swapped around, the option codes are nearly meaningless in a lot of cases.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 06-18-2005, 11:29 PM
Ornery Bastard
Only discussing the '86 951. I already knew the '86 N/A didn't have it. But the NA had an entirely different transaxle too.
Old 06-19-2005, 10:44 AM
Did you get the memo?
onewhippedpuppy's Avatar
I think all the '86 951s had the cooler and forged rods. When you get the car check the codes, under the back carpet on a tag by the spare.
‘07 Mazda RX8
Old 06-19-2005, 06:52 PM
Actually the M758 code is for the '88 ONLY 951 Turbo S option and this included the M220 option of LSD trans. You will not find the M758 option on any other than a '88 turbo. The M756 and M757 options were for the 924S and the 944 '88 special models.
AaronM,
You want to look only for the the M220 code and if it is the original trans it will have a cooler on an '86 951.
Old 06-19-2005, 09:39 PM
Yep, had I actually read my notes properly..M758 is for the S....
Old 06-20-2005, 09:55 AM
Every '85 951 I've seen has the oil cooler, but most '86s did not come with 220/lsd, I've only seen 2 (both black on black, coincidentally).
Old 06-20-2005, 10:35 AM
Eric 951's Avatar
Mine has LSD--white on burgandy, and the cooler
Eric
83 911SC/83 944
bunch of Honda 750s
Old 06-20-2005, 10:36 AM
