Question about Fuchs?
How much do a set in good condition typically run? How do you tell if they are replicas?
1984 944 N/A 1996 Golf Gl Drive fast. Take chances. If you can't dazzle them with brilliance, baffle them with bull. - W. C. Fields |
I've heard 1000+ to upwards of 1500 for used originals in good condition... haven't any info on telling originals from replicas though....
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
meister member
I bought my set of 16" X 7" with almost new tires for $400 from CT. They are the originals and not the fakes. You can tell by the serial numbers on the inside of the rim.
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
meister member
The $400 was cheap. When I was shopping I found them priced between $1000 - $1200 just for the rims.
I have a set of 15" x 7 & 8" Fuchs on my '85.5, and the part numbers (visible on the back) are as follows:
7"= 911.361.020 41 A320.62 8"= 911.361.020 42 A510.62 You can also look for the Fuchs (fox ;-) symbol and other stampings as well to determine if the're real or replicas. Brian
'85.5 944 (sold and will be missed) Sport seats, LSD, sways, 7 & 8" Fuchs |
Re: Question about Fuchs?
The cheapest and most abundant are the 15" and 16" (6's and 7's) with the 911 part#s. They get pricier as you get into the oddball ones, like the 951#'s (16X7 and 16X8 with clearance for big brakes) and the 930 16X9's. Even pricier are the really rare ones, like the R, RS, and RSR Fuchs. Real Fuchs have a 911 or 951 part# on the backside of the petal, like others have told you. Honestly, replica fuchs are good wheels too. They are a little heavier, and a little more brittle if you whack a curb, but otherwise they aren't bad. All Fuchs are old (last year for them was 1989), so one should be periodically inspecting their wheels anyway.
1985.5 944 Club Sport My P-caronline Profile "A good time to keep your mouth shut is when you're in deep water. "-- Sidney Goff |
Thanks for all the info.
