finally running, but now no power
Hi,
OK, I solved the no start problem, turns out the rear speed sensor was barely disconnected where it plugs into the rest of the wiring harness. You couldn't tell by looking at it, I pulled on it a little and "tink!" it disconnected. Clicked back in and it started.
Now the problem is that it runs a little rough and has no power. The idle is about 300 rpm low, and the throttle response is really slow. It runs even and idles, and won't stall, but it acts like it's not getting enough fuel.
It used to do this occaisionally when it was running correctly: hesitate/no power/super slow throttle response for a couple of seconds, and then snap out of it and ZOOM!
Any ideas?
Old 06-26-2005, 02:29 PM
Opps, I forgot to mention:
84' 944, new belts and water pump, new pressure regulator & damper, new temp sensor in the head, new DME (used). It sat for most of 22 months after the water pump blew, while we moved. Then, I got parts, fixed things and solved the no start problem.
Old 06-26-2005, 02:34 PM
SoCal Driver's Avatar
Might have a vacuum leak between the AFS and the throttle body. Check the large J shaped duct and it's associated vacuum lines.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-26-2005, 02:51 PM
carsonmx114's Avatar
maybe the flapper door on air meter is sticking?
86' 951
k26/27 hybrid turbo
01' audi s4
98' TDI jetta
96' 933tt AWD LS1
Old 06-26-2005, 06:10 PM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
maybe the fuel filter?
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 06-26-2005, 07:36 PM
After sitting for two years yes it could be a clogged fuel system. Filter as above and the injectors too. The injectors can be taken off and back flushed with shop air and solvent.
Old 06-26-2005, 10:28 PM
