running on 2 cylinders?
Ok guys I need your help again. I changed my intake manifold gaskets. Sigh I didn't get new injector seals at first. Old seals were hard and brittle and they leaked when I put it back together. It idled a little rough but still ran good. So I got some new seals and installed them. Now it seems like it's running on 2 cylinders. I checked spark to all plugs. I also removed fuel rail and observed injectors. they were all shooting gas. Now at about 5000 rpm in 4th gear it bogs and there seems to be no acceleration when i hit 5th. Any ideas. 1989NA.
Thanks TG
89 944 na Dove Blue Metalic 2000 chevy silverado 2000 chevy 454 dually black 79 GMC short bed 4x4 4 quarter horses 89 acura legend GS sedan |
I also unplugged each injector plug and 2 of them made no difference in the way it idled.
Thanks FR goin check now
BRB
will a big ole crack in the intake boot make it do that?
I think thats the problem.. Thanks
It's guys like you that keep us poor ole boys runnin
I ordered a new intake boot. In the mean time i tried taping up the gapping crack. Didn't seem to help.the whole thing seems cracked and brittle. Guess i'll just have to wait for the new one to come in. if that don't fix it reckon i'll try fuel regulator
ShoeGoo.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Blue epoxy will fix almost anything.
'77 924-- It's Alive! |
Duct Tape.........
Every porsche should come with a roll. They make great timing belts.
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
Socks.
I got the new boot in. installed it. no change. Looked at plugs they seemed to be fuel fouled.I cleaned them and reinstalled. no change. Checked fuel pressure. about 45 psi.
A 4 cylinder engine wont run with just 2 cylinders. At least 3 cylinders must fire up in a 4 cylinder engine to run.
1984 Black 944 (w/'83 engine & P/S) 2008 Ford Explorer XLT Last edited by morbid; 07-14-2005 at 05:41 PM.. |
fuel pressure is about 48 at idle. Thats prolly to high.huh?
About 12 pounds too high. See if the vacuum is hooked up for the fuel pressure regulator. If it is pull of the hose and see if there is gas coming out of the regulator.
Replacing the FPR is tricky. Don't hold the fuel rail when you loosen it. Use a large wrench on the big "nut" to hold it. You will crack the fuel rail otherwise.
does anyone know how much vacuum is pulled on the fuel regulator?
I found a messed up intake gasket. Replaced intake gasket. Also found one of the intake vacuum hoses under the manifold had come loose. It seems to vary on the fuel regulator pressure I have read anywhere between 35psi and 48psi.But you think about48 psi on an 1989? Anyway it still seems to miss at about 5500rpm. Could it be from the hole in the intake boot getting the throttle body dirty? It also fuel fouled the plugs I cleaned um but I think news are in order
One more thing. Would excess fuel mess up the o2 sensor?
No. But it sure beats up the catalytic converter.
Factory manuals list fuel pressure at 2.7 bar. Were did the 3.3 bar come from???
